88 ranger 2.9 erratic idle, sudden rpm drops idle and load, sputtering just when cold, slowly acceleration and can’t go above 60 mph
WEBB CITY
MO - USA
Vehicle
Drive
I have an 88 ranger xlt 2.9l dual tank. I have done many things to it I’ll list below. I have also tested lots of things I’ll list below.
The issues I have are as follows; it has erratic idle, sudden drops in rpms when idling and when accelerating. Happens more when under heavy load and acceleration. I also have an issue where if I just hop in the truck start it up and go drive when engine is cold it will sputter maybe 10 times until it warms up and then it stops sputtering. Usually it doesn’t sputter after it warms up unless I turn off the truck and then turn it back on. Then it only does it once or so. I also can’t get the truck to accelerate above 60. It seems like it has a lean or rich mixture or something like that when accelerating. It accelerates slowly as well
Replaced:
-distributor, including cap and rotor
-ignition coil
-spark plugs and wires
-fuel injectors
-high pressure fuel pump
-fuel filter
-upper and lower intake gaskets
-any other gaskets you can replace when doing intake gaskets
-map sensor, o2 sensor, coolant temp sensor, intake air temp sensor, oil sender
Tested:
-compression test was stock compression on all cylinders (190)
-vacuum test was good. I believe it needs somewhere between 20-24 hcg and it was 23
-iac valve I’ve replaced and it didn’t change anything so I put the old one back on
-throttle position I replaced and didn’t change anything so I put old one back on
I want to test my fuel pressure at the rail but none of the fittings I’ve tried will fit my ranger for some reason. I went to oriellys and their kit didn’t fit.
I do understand as well that any of the parts I’ve replaced could be bad out of the box so any comments or suggestions are welcome. I just want to get my truck running well and I can’t seem to get it to run. I’m chasing my tail it seems like
Yeah I need to do that. I appreciate your input and will get back with fuel pressure readings. My fuel gauge doesn’t work as well. I believe that’s early signs of my in tank pump going out
What did plugs look like when you changed them? Might tell you if it's lean/rich. The Harbor Freight fuel pressure tester I have has the right fitting.
I believe the last time I pulled them they indicated lean. And I might have to go see what my harbor freight has for testers
Did you keep your old injectors?
Replacement injectors are a buyer beware kinda thing these days. If you bought the cheapest on Amazon or ebay... I'd put the original injectors after clean and test was performed.
Yeah I kept old injectors. I installed factory oem ones but I wasn’t 100% sure if they were going to perform correctly. I had heard the same thing and potentially just to get the injectors cleaned but it was the same price and figured why not go with new. If you are thinking I should get them cleaned and try it out I definitely could.
That's on you... glad to see you kept them.
I have a factory set i was going to send out and have done.
There are places that sell tested matched sets... spendy... yes. Worth it... probably.
Seen you have checked several things. I dont see your Fuel Pressure Regulator on the list. I have had that to fail. I have seen in the computer that some capcitors fail, you can open it up and see them right away. I would do a fuel pressure test like others have mentioned.
I have same truck as you, I had an erratic idle. Mine wound up being the aftermarket TPS, I installed a used factory Throttle Body Assembly and fixed mine. Also there is a fine setting on getting the TPS adjusted correctly. Another reason I went with a used assembly.
I found the video on TPS adjustment and IAC servicing that you posted on your restoration thread. Great info.
Can someone tell me where and what to search to check out this TPS adjustment video?
Regarding the idle problem, with everything that has been replaced or tested I would open the EEC and check for capacitors that have begun to leak. The intermitent nature of the problem makes me suspect this.
Check these links:
Look for the thread, "My 87 Ranger that I will be restoring soon" then go to page 33 in the thread. Tried to post a link directly to it but it puts you on page 1.
Link to the same video on YouTube:
Similar info from a shop manual, in another thread: https://www.therangerstation.com/forums/threads/2-9l-timing-help.194538/page-3
I have the paperback Chilton manual for 83-91 Ranger and it has zero info on this. 2.9 tech article, maybe?
Sorry for deviating from LittleDevinBro's issue, but this is related.
The shop manual procedure I have used and I think it is correct. I assume the Don't Touch That warnings came from EFI being so new to mass production back in the eighties. I don't think it's necessary to tinker with the TPS to get the voltage lower than 1.3v into a range like 0.92-0.95v (what Terry's video refers to). Why?, well, there's no adjustment on the TPS. So I did a related search and came up with this thread and stangPlus2birds' explanation of why it doesn't matter so long as it's less than 1.3v (https://www.corral.net/threads/does-any-1-know-what-wires-to-check-tps-voltage.472371/). That sounds correct to me. The computer will figure out what the voltage is (it actually does something more complicated, has to compensate for things like 12.2v if the battery is good at startup and 13.5v once the alternator is spinning, hence the reference wire) at idle and adjust accordingly. I'm also going to re-read the TPS section in the EEC-IV book in the tech section and see if it addresses this.
Update: The Engine & Fuel System page of the '83-'11 Tech section also has a link just about testing the TPS (https://www.therangerstation.com/tech/throttle-position-sensor-tps-operation-test/#gsc.tab=0). Note this states "You need to back probe the harness while reading the voltage between the TPS and SIG RTN pins.", and they're diagramed. Set screw is for changing the base (no IAC) idle. TP should read low and have smooth transition as throttle changes,
