- Aug 20, 2025
- Sacramento
- State - Country
- CA - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 3.0 V6
Hello,
Anyone got any ideas on the problem for my symptoms? I’ve got a 1999 Ranger 3.0 4x4 automatic flex fuel and it seems like the truck is misfiring. When at idle if I hold the rpm around 1200-1800 rpm the engine shakes intensely but fast accelerations and higher rpm’s the truck drives completely smooth. Also when cruising and reaching a higher speed for example 65 mph and the rpm drops as i maintain steady speed it will also begin to shudder until either I let off the gas completely or rev it higher. Also during this engine shake my live data shows that the engine load percentage is extremely high(80%) even though the rpm is in the 2000 range, also during this I discovered my downstream B1S2 O2 sensor is reading very low which means it is running lean? So far I have replaced MAF, cleaned throttle body. Checked for any leaks behind the MAF. Cleaned EGR, tested fuel pressure, swapped fuel filter, spark plugs and wires as well as testing them. There are no codes on obd2 reader and everything else checks out.
Im planning to clean fuel injectors, swap ignition coil, and IAC to see if any of these fix the issue
I’d appreciate any info or tips. Thanks y’all
