I have a 97, 4.0 4x4 and the AC Sye=stem is empty. I would love to find the leak myself so I have a better understanding of what repairs need to be made. I have a set of AC gauges, a vacuum pump. When I put a vacuum on it it looses it in seconds. I do not want to invest in a N2 system so I am curious about using shop air. I would like to find a fitting that allows me to connect a shop air hose to the yellow hose so I can spend some time with a stethoscope and soapy water to find my leak(s). I suspect the fitting to the compressor. I pray it is not the exchanger in the dash. Is there a way to assemble an air hose fitting to the vacuum hose on the gauges set. I know the dryer needs replacing. I know the clutch works, but with NO freon in the system it is a bitch to find the cause. Thanks in advance.
