Still chasing missfire....UPDATE....SOLVED
You will have to trace it out and see where it goes. Lots of green wires under there. You said you had the harness tape off.
I think i answered my own question.
I found a wiring diagram and i *think* its a tachometer wire. It did appear it was never attached to anything...which would make sense cause i dont have a tach
So like... is this issue SOLVED?
I have an 86 EVTM...
You want a diagram from it?
if you can post it, the only ones i found were 87\88 but i figured they were the same
I guess whats got me bugged now is the pinging. Obviously the timing is to advanced (havent had a chance to mess with it since thurs).
I can buy whatever was screwed up was preventing full advance with the spout in, but not sure how it affected base timing with it unplugged....i set it at 10 before i found the issue.
Unless its still at 10 and something else is off.
Worse case ill just do it old school and back it off little by little till it dont ping.
Ill know more monday
I'll post what I have a bit later...
Got to finish up my garden chores. Got enough harvest for a batch of pickles... a batch of salsa... and a batch of banana rings.
You mechanically set the timing to 10BTDC with the SPOUT disconnected (no computer control). After that is done, you plug the SPOUT back in, now the computer takes over and sets the timing. The 86 setup did have a knock sensor. I want to say it's on the side of the engine block on the driver's side.
Thats what i did.
Yes it has a knock sensor but im running an 88 ecm.
You are correct. The 86 has the sensor hooked to a yellow/red wire and going to pin 23 on the computer. 1988 does not have a pin 23 in the diagrams. And of course no knock sensor hooked to it.
and also has a more aggressive non egr timing table.
Really? I thought the earlier trucks ran a hotter timing table because the knock sensor could correct?
There what I got... forgot to do it yesterday Rusty.
back in the late 80s early 90s i went to a distribution house for helm on 59 that some say is not a thing. i not only got the stang, econoline/150/tbirds/mark 7 harness diagrams, i got the layout setups with inches for each wire and routing.
this is how i knew that the harnesses were factory hacked in production in mexico, they were modified off print to hold production.
shit i wish they would do now. there is a point to that i might get to later....i am sure gump knows the setup i am referring to.
Ya know bobbywalter...
The company i worked for was off 59... Rochester Hills. We were doing a bunch of Ford work for BA and DAS. We did EVTM and Service manuals for a couple platforms you mention. I got hired for the Super Coupe... I grew to hate those birds.
We had piles of blueprints and technical data.
The harness diagram is what I seem to have for a 1986 Ford Ranger/BII. It is very very difficult to read when you want to logically follow a circuit. It's priority are the wiring grouping and the harness plugs. It's a very large fold out system of diagrams. Not very good for troubleshooting.
