1996 Sapphire Blue XLT build
You may want to spray the headlight lenses with some UV resistant clearcoat, or they’ll oxidize quickly. Looking good though!
Thank you! I did that right after sanding and polishing them.
Been a while since ive made an update. The website has been painfully slow lately, am i the only one?
Loaded up the paddleboards yesterday and did some paddling, enjoying the nice weather.
-replaced the diff cover, started leaking though a tiny pin hole
-new blower motor resistor and harness because the old one was corroded and melted.
-got the AC recharged, hoping theres no leaks
-got some infinity 6x8 off market place for cheap, so finally have good speakers all around
-trying to drive it more to get all the bugs out of it so theres no worries when im driving it.
-still on the hunt for a sapphire blue passenger door
-need a new gauge cluster with a working odometer, id like a tach on it too.
-still cant figure out where the leak is coming through on the passenger side, might need to pull the fender to look.
true, but isnt the door striker on the B-pillar? I wash you could pull the cowl on these rangers, i would make it a little easier to find
Yes but, water migrates. It can come from almost anywhere.
You're right, removing the fender might be the ONLY way to find the source.
Its probably in the cowl, firewall, or windshield area. every older ranger ive seen has atleast some rust in those areas.
