AHenry014's 1998 Ranger 2.5/auto to 5.0/manual swap
AHenry014
Forum Member
CT
2.5L
In this thread, I'll be documenting my 1998 Ranger 2.5/auto --> 5.0/manual swap along with any questions I have along the way. The truck was "Pepe's" truck, my late grandfather-in-law. When he sadly passed away at ~98 years old, the family mulled over what to do with it. His "little blue Ranger" had some rough years and we all knew it needed some attention. Instead of sticking it at the end of the driveway with a for sale sign, I stepped it to take ownership of it since it had such great sentimental value. I've had the truck for some time now and have made some marked repairs and improvements to it; drivers floor pan repair (rear glass leak, Sherman 576-40L fit nearly perfect), 4/5 DJM lowering kit, 1997ish Mustang GT wheels, custom side exit exhaust, etc. The truck has been a blast to drive, but lets be honest, its SLOW, and I've never been one to leave anything alone.
An LS swap was floated, as I've done a couple of those in the past. I actually have a "spare" cammed 6.0 sitting in the garage that was meant for my third LS swap, but I had a hard time doing "the same old thing" again. I wanted something different, something new to me. Now that I have evolved into a father of two, my free time has decreased to next to zero, so I also needed something that wasn't going to take months on end to complete. After some brief research, a 5.0 swap became the obvious choice. It's certainly not a novel idea, but the last time I spent any time on a SBF was over 20 years ago, so it satisfies my desire to try new things.
After doing my research here in the tech library and across various threads, I kept an eye out for a suitable explorer or mountaineer. I had several saved on FB Marketplace until the "perfect" one popped up, a 1999 Mountaineer, 184k miles, runs/drives, brakes no good, rust throughout, etc. A couple items in the listing justified the list price of $1400; OBX headers (NLA), DUI Firepower ignition kit ($289), and that it was listed as being RWD. I was initially set on manual swapping the Ranger during the engine swap, but figured this would be a drop in solution from radiator to rear axle. Unfortunately, it turned out to be AWD, and it didn't run very well (seemingly missing on one or two cylinders). I was able to talk the seller down quite a bit due to the unknown reason it was running poorly and that it was misrepresented as a RWD truck. Got her home and started digging in. One of the spark plug wires (#8) was not a DUI Livewire and failed testing with no continuity. I also found cracked porcelein on #4. A set of Motorcraft plugs and Motorcraft plug wires later, and it seemed to be running on all 8 again. There is a lot of the Mountaineer that I can resell, which I hope recoups most of the initial investment cost.
Now to the swap strategy. Its a '99 Mountaineer, so I am good to go on the fuel system and speedo (assuming the rear axle checks out before being swapped into the ranger). As for the PATS, I have no issue swapping the bits into the Ranger to retain it, but since I'll be going manual, the auto trans bits will need to be tuned out. In my research, Drag Radial Performance seems to pop up quite frequently. I'm going to ask him to take care of the PATS at the same time to simplify the swap. I'll report back with any comments and pricing using his service.
As for the trans, I have landed on two options:
1. The easiest seems to be the M5R2 F150 4.2 trans. I've read that its essentially bolt in, the shifter location is right, the clutch hydraulics are shared with the ranger, etc. The only "downside" I have read about is that it is a truck trans, and will shift and feel as such; long throws, delays into next gear, etc. I assume it will drive similarly to the ZF5 in my cummins swapped brick nose or the NV3550 in my LS swapped Jeep. Not a deal breaker by any means, but something to keep in mind.
2. A friend of mine has a fox body T5 world class available. I have yet to put eyes on it, but am told he bought it new and it was only used for a couple thousand miles. I've never driven a T5, but have a feeling it shares a similar "feel" to that of the T56 I had in my LS swapped BMW. I have read that if you want it to drive/shift in a more "sporty" way, then this is the way to go. I haven't come across a photo of where the shifter comes up through the floor using this transmission, but have read its a lot further back than the OE Ranger location, somewhere just in front of the seat. Looks like I'll need a hydraulic clutch kit for it, which I see available for around 250.
Any thoughts on the trans options above?
I will certainly post back with progress, questions, and of course, photos!
Thanks all.
Sounds like an adventure!
there is nothing t56 about a t5.....maybe a worn out lt1 95 camaro would be similar....but the later units and magnums are wowz comparably.
for a low rider 2wd truck with a typical cammed 302, the t5 is a decent option. if you want to play hard start saving for a tkx.
so driving the mountaineer, what are your impressions?
there is no way i would dump the level of money into the mountaineer engine to get to what i had sitting with even a stock a 6.0, especially if time was critical and a herd of boobie biters competing for attention...
of course doing something new has a value in time and money and patience that has its own expansive rewards...i can really understand it if that is the case.
being that it is paps truck i would lean towards mild and keep it around as long as possible...
this system has my curiosity peaked....if i put a sbf together i may use this. good 230/236 cam and decent heads
it would sound awesome.
Thanks for the response. I know these SBF's dont really hold a candle to even basic LS-based engines, but I dont really want or need that sort of build this time around. For now, id like to keep the engine stock to get my initial impressions. If I desire more power, then I'll start doing research.; cam, heads, tuning, etc.
The mountaineer drives OK. It is certainly no power house, but its possible the AWD system/auto trans is sucking a bunch of that up. Still torn on the trans front. I'm leaning toward the F150 4.2 trans route to keep things simpler. Ultimate decision would be to see where the mustang T5 WC shifter pops up through the floor. If its in a goofy spot, it will solidify the M5R2 route.
Was able to find a couple photos of where the T5 shifter ends up. One fella had it incorporated into a modified explorer/mountaineer center console, which looked nice, but I don't plan on installing one. Another photo I saw had it poking up through the floor between split buckets, which to me placed the shifter too far back (and it looked goofy). I feel the best way to move forward is the M5R2. Now onto sourcing one.
Haven't made too much progress in the past two months as I've been sorting other priorities first (projects, infant, toddler, etc). I was finally able to get the Mountaineer into the shop to strip some parts and get some further diagnosis done. As they do, things seemed to snowball. Good news is I pulled and sold the mud terrains that came on the Mountaineer for half my initial investment. Its got a handful of other bits I can resell while it still staying a roller, so we will see how close I can get to having zero investment into this thing while keeping what I want.
The bad news is that I still didn't feel like it was running quite right based on a shaky idle and inconsistent exhaust note. I grabbed my temp gun and shot each header tube to see if all were firing, and #4 was markedly colder than the other 7. I pulled the plug to verify spark and also verified compression in that hole (~150psi). That led me to believe I had a dead injector, so I "stethoscoped" a couple using a long screwdriver and there was no audible injector actuation on #4, so I tore the intake manifold off to investigate wiring. The #4 injector connector clip broke as soon as my thumb touched it, so that will need to be fixed. I verified the injector has resistance, but does not actuate via a power probe. Voltage to the injector is good and continuity of the other wire up to the PCM is good as well. So confirmed, shes dead.
So here I am, staring at the thing I have partially torn down, wondering what the point of putting it back together would be. I want to at least reseal and make it look better before jamming it into the Ranger, so theres no sense in using up a couple gaskets just to run it for a minute, to then tear it back apart for clean & paint. I ultimately decided its time for the engine to come out and be on the stand. That said, I plan to do a full compression test to see where 184k mile engine health stands.
I did get in touch with "PontiSteve" at Drag Radial Performance about tuning the PCM. He will be able to take care of it. I will report back with my experience there when the time comes.
More to come!
Do you have any pic of the truck as it is now?
I go back and forth on motor swapping my 3.0 5spd. LS is best power wise, but 5.0 is easier for a motor swap, but I wouldnt want to convert to automatic. Half the reason i bought my 96 was for the manual.
But driving my ranger, i have zero desire to speed in it, its fun to just cruise around.
Surprised I didnt mention it above, but the transmission in the ranger is dead, D-U-N, dun. While on my way to work a couple months back, it popped into a strange free revving neutral at about 50mph. I gave it a rev or two and it acted as if I put the transmission in neutral, then BANG! She's back in gear and moving along just fine. I get it to work and back with no issues; fluid level good. I keep driving it until it happens again, this time with a harder bang. Pop the hood again to check the fluid level and it was a touch low, but nothing that should have caused transmission behavior issues. I added some to get it up to the full mark, maybe a half quart or so. It drove around the neighborhood fine for a while but started acting up more frequently until one forward gear decided to leave the chat. It wouldn't move from a stop in OD, but it will in 1. I figured out that I could get it to skip whatever failed by starting out in 1, getting up in the rev's, and shifting to OD. All was fun to tooting around the neighborhood until reverse failed. Party's over.
I am currently working to clear the garage of crap so I can get to work on this thing. Hopefully that will come to fruition this weekend, but we shall see.
Here are some random pics. Here it is at stock height.
Dropped 4/5 on DJM kit. Maybe I should put these wheels back on, they look kinda rad haha.
Mustang wheels. Wasnt a huge fan of them initially but they've grown on me.
The donor. In its day, this would have been a unit to drive around, but she's RUSTYYYY, so I have no qualms about taking her apart.
I will get some more postings done here when I start taking things apart.
Do you have te 42 pin connector pinout? Im trying to find.out if it is a.direct plug to the explorer harness
I was under the impression they were essentially plug and play.
Near the bottom of this tech article talks about some wiring modifications that may need to be done:
The mod's appear to be year specific, so depending on what explorer you have and what truck your swapping, YMMV.
im digging the lower lip on the mountaineer too.
I thought the same! The front bumper is actually one big cohesive piece of plastic vs the steel upper/plastic lower valence that I have on the Ranger. I'm not sure its OE, but will take a look when I remove it. Its a bit cracked, but certainly fixable. Since the truck has some paint issues, its going to be a backburner thing until I decide if I want to spray the whole truck, or just attack the bumper.
As a short update, I sold a project vehicle that sat untouched in the corner of my garage for 5 years. Just a bit more clearing/organization and Ill get the mountaineer shoved in.
Thats surprising, it looks like a lower valence. I might look for one myself. My ranger needs something more for the front bumper.
I know it is on a 3.0 truck.. I just picked up.a 99 2.5 truck to swap..its a 2.5. Im trying to figure out if it is in fact plug and play like the 3.0 rangers
Small update. A couple months, I got the mountaineer into the garage just before the "big" snowstorm we had here in CT. While the snow sat on the ground, I was finally able to dig into it. I got the front end mostly torn down to make further disassembly easier; bumpers off, hoods off, rad's out, etc. I think I am going to conduct a compression test on the engine to confirm health prior to removal and now is the time. After that, the next step is to make the non-removable radiator support removable, then headers off, torque converter/bellhousing bolts, etc. and out she comes.
Progress is slow due to my ~16 month old's every changing sleep patterns, along with other small projects stalling the efforts.
Upcoming TRS Events
Featured Ranger Based Vehicle
