sgtsandman
Automotive Technician
TRS 25th Anniversary
- Mar 11, 2017
- Aliquippa
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Tire Size
- 265/70R17
- My credo
- Anything that can go wrong, will go wrong. Plan for it as best you can.
I appreciate everybody’s responses. A little bit more about what I’m thinking. I have access to a very good running four-wheel-drive short cab short bed, almost exactly like my 87. And what I’m considering is another mini semi type project like I did with my 97.
My 87 with the 2.9 is fantastic for just tooling around doing whatever, hauling small loads, or driving down the interstate at 75. Really a great all-around little utility truck.
What I’m thinking of doing, is a similar double axle (or maybe a triple axle this time), with an aluminum trailer that may be three axles, with a low deck set up so it becomes an easy car hauler. A mini “tri drive” heavy hauler toy thing.
Before everybody jumps, this has nothing to do with right or wrong or the best way to move a car or any kind of common sense. It’s another big toy and crazy vision.
I’m not looking for a hot rod at all. Gas mileage doesn’t matter as long as it doesn’t drop to 10 miles a gallon What I want to be able to do is get more “tug off the line“ torque power, but still be able to go down the road at 60 or 65 miles an hour, and be able to drive uphill, even if I have to drop a gear. One gear. I want the engine strong enough to go 60 or 65 or 70 in an ideal world down the interstate, but if I come up on a hill (or a jerk in front of me), I want the torque to be able to downshift and climb the hill without dropping to 30 miles an hour or something like that.
In an ideal world, I would do this with an extended cab like my 97, but I’ve got my hands on the short bed short cab right now, and it’s a 2.9 with the five speed. All that is for clarity on my “vision.” or maybe clarity on my “delusion.“. I love my 97 for what I did to it, and if I found one in decent shape with a 4.0/5 speed, it would absolutely be my first choice. But I don’t wanna spend any money.
Having said all of that, I had a completely different thought. I have 235/75/15s on both trucks now. The 97 4.0 works perfect perfectly for this kind of stuff. The 87 seems a little underpowered when I climb a long hill even empty. If I downshift, it’s fine. But if I’m pulling a load, I would prefer to downshift as little as possible.
I have a pile of wheels out next to the shed of miracles, and I have a bunch of 185/65/14 tires on bullet hole wheels. Bullet holes would be my preference for a project like this. If I simply swap those two wheels/tires, it goes from 699 revs to 860 a mile. Wouldn’t that accomplish the same thing as putting in taller gears?
I’m not sure if I’m a fan of the appearance of smaller wheels and tires, but so much behind the doors will be custom, it’s just a matter of making it look right.
so, forget the best way to get it done, what’s the cheapest way without actual chickens running in a wheel on the roof?
Then 4.10:1 might be a better choice for you for that build. You'll either even out on the mileage that the truck is getting with 3.45:1 or maybe a little less.
As far as the '87, have you looked at smaller 15" tires used on the Rangers in the past? 225/70R15 is common on RWD Rangers and might be a big enough drop in radius to get where you want. Effectively bumping up the gear ratio a bit. Perhaps 215's might get you there as well. Both are going to open up the gap between the tire and the wheel well, if that is something that matters to you.
