2.3L ('02-'11) The year is 2025. Anyone know where to get a fresh 2001-2003 2.3L intake manifold?
Yes! It works!
Later intakes have five ports at the back of the manifold instead of three. You cap two of them off.
Otherwise, zip tie the IMRC actuator up somewhere.
The shop that helped me with it also had to tee the little vacuum line off the fuel rail in somewhere too but I dunno what that is even.
Overall works great. Runs a little wimpy at low RPMs when you first start it up. Once it's warm it runs the same. Same gas mileage, if not a little better. Much quieter. Totally do-able. I'll take some photos or a video or something when I have time.
If you find the time.. making an article for the tech section about the process with some decent pictures & a description could help out a load of people in the future
Yes! It works!
what part number manifold did you get and where did you order it? im looking online and cant even find one for an 04-11
yes this would be insanely helpful, some kind of write up. im looking to do this to mine as soon as i can find an 04-11 manifold
I fully intend on doing that.
Still had to source one from a wrecking yard. Still was hard to get. I believe the PN is 4L5Z-9424-AA but Ford discontinued them just like everything else for the good Rangers because they suck. But there are 8 years of manufacturing behind those, vs. 3 years of mfg for the IMRC ones. And zero moving parts.
I actually have an extra one sitting around I'll sell, but after I get photos and documentation for the write up above.
i'll buy that from you ASAP please let me know
I'll still sell ya mine when I'm done with it but if you need one sooner this one popped up on ebay! Looks clean too.
I had a shop do the work, I didn't do it myself. But they swapped the throttle body over.
Later rangers are drive-by-wire instead of using a throttle cable, I don't know if that matters but your old throttle body should work.
A Canadian Ford dealer has the 4L5Z9424A manifold new, but the part costs nearly US$500 including freight to the US. Here's the listing:
Count the intake passages on your link.
We need 4L5Z-9424-*AA* for a 2.3L ranger.
The "A" model is for 6 cylinder engines.
Would love to see some photos so I can do this to mine, I’m in the same endless forum searching boat you were a few months back.
The truck has run really well since the repair was done... until I started getting a gross misfire this last week, not sure if it's related.
If I can sort that out or at least be sure it's not related to the intake swap, I'll post a video when it's running good.
Edit: I had a shop look at it, and apparently the 1 year old NGK coil pack I installed was going out. Lame.
much appreciated!
