sgtsandman
Automotive Technician
TRS 25th Anniversary
- Mar 11, 2017
- Aliquippa
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Tire Size
- 265/70R17
- My credo
- Anything that can go wrong, will go wrong. Plan for it as best you can.
I did some work on the Escape and discovered more of why it was on the used car lot. It looks like the valve cover gasket is leaking. Looking at all the stuff that needs to come off in order to do the job, my guess is that the shop quote for the repair was high and the PO didn't want to pay it. There are all kinds of signs that someone was there. Broken plastic mounts, missing covers on things, the missing splash shield underneath. The leak isn't bad but it will eventually foul up the spark plugs because of how the valve cover is designed. Stupid design but the job is doable.
When I get to it, I'll take a gander at the oil supply line for the turbocharger. Based on what I'm seeing with the valve cover gasket, I doubt it is leaking but while I'm there... I hear that the line has a screen on it like the 2.3 does. So, if nothing else, I'll make sure it is clean.
And I did some more work on the storage rack for the carport rafters. The upper support for the tarp is almost done and I installed some hardware cloth on the sides and ends of the floor slats to keep hornets and wasps from building nests inside. The center still needs to be done but I ran out of mesh to finish the job.
