RobbieD
2.9l Mafia
- Aug 6, 2007
- Georgia
- My credo
- Toonces drives a Ranger . . . . just not very well.
That is an odd one.
The only thing that I can think of is a weak connection somewhere; like light switch contacts, harness terminals or a loose or corroded grounding point. BUT, I would expect such an issue to also cause the lights to intermittently drop out after they've been turned on.
And I doubt that it's on the ground side, because the high headlights don't have the problem.
How consistent is this symptom?
*If it were me* I'd pull the light switch, and use a quality jumper lead to jump the power and low beam terminals in the switch connector. If this test still has the low headlights having a delay, look downstream from the switch (from the connector through the wires, harness connector and headlight terminals, and to the ground. If the the problem can not be made to happen with the jumper test, look hard at, or replace, the light switch. And make sure that the light switch connector doesn't look "toasty".
My guess would be the light switch (I can only offer a guess, 'cause I can't afford a lottery ticket anymo')
