Torx bolts size on driveshafts/transfer
oystein
20+ Year Member
Norway
Going to remove my transfer case. What size are the torx bolts holding the driveshafts. Have to buy the right size. Looks like E13 and E19? Right?
btw is a 97 with electrical shifter...
T30 for the front to diff. Rears are a 12 point 12mm.
AFAIK, the only "E" type Torx driver needed on the truck is an E-7 to remove the fuel rail studs.
Aren't the flywheel bolts on a 4.0L external torx? Or was it just the SOHC?
The above is correct.
The t-case side of the front driveshaft is 8mm (12-point).
Maybe the SOHC. Not the OHV.
They are "special" (really fine thread) hex-heads.
Negative, Maurices '97 Ranger had the external torx bolts on his flywheel when we did the manual transmission swap on it.
