- Jul 31, 2024
- Louisiana
- 2.5 (4 Cylinder)
Hi All,
Firstly, I would like to thank TRS and the author for this detailed article, Ford Ranger Odometer Gauge Swap - The Ranger Station .
It seems the author is no longer active in TRS and hence I am reaching out to you all for help
Luckily, I was able to find an instrument cluster from a Ford Explorer (Year 1998 or 2002, can't recall) which is exactly the same as the article, the only problem is the instrument cluster in my 1998 Ford Ranger XLT 2.5 L RWD does NOT have Vehicle Theft Indicator/Sensor. However, the one that I found from the local yard appears to be same as the article has a vehicle theft indicator.
To summarize my new cluster has all gauges as the old one with two additions, one is the Tachometer and the other is Theft Indicator.
I am wondering if I could make this swap ? My reason for swap is to have an RPM gauge in my Ranger.
Any suggestions are much appreciated, thank you for your time.
