2.3L ('83-'97) wrong ecu?
the_intimidator03
Roseburg. Oregon
I bought a 1991 Ford Ranger std cab 4x4 5 speed. I got a code for 22 (MAP) however do not find a map sensor or plug in on harness. I do have the mount on cowl (where my parts truck has one) After doing some inspection, I noticed the ECU was E9TF. Truck was built 08/90. I believe I have the wrong ecu for the truck. Could anyone point me in the right direction?
I did a google search, it comes up with 5.0 computers but it also came up with a 1989 ranger. How many flashes or indications did you get when you first pulled the codes? That gives you a indication how many cylinders the computer is programmed for. 2 flashes, is a 4 cyl, 3 is a 6 cyl, and 4 is a 8 cyl.
Most all engines those years used a MAP sensor.
The 2.3L switched to MAF in mid '90 model year so roughly around '90 (my '90 had a MAP sensor but was built in '89), I think it's similar to when the 2.9L switched to MAF as well.
With an E9 it's probably the wrong ECM, you're likely going to want a '90-92 ECM for it to work right.
that is what I figured, not sure the differences besides the manual vs auto. figure look for f0 or f1 ecu
Here are some used ones in Oregon.
1989
Engine Computer
C/R,2.9L,5SP
X​
9052D
$45​
B and K Auto Salvage USA-OR(La-Grande) Request_Quote 1-800-233-9640 Request_Insurance_Quote
Live Chat
2065​
1992
Engine Computer
8/91,2.9L,5SP
X​
2272E
$45​
Live Chat
2065​
1989
Engine Computer
Ford Bronco II
03/89,2.9L,5SP
C​
3845E
$45​
Live Chat
2065​
1989
Engine Computer
Ford Bronco II
EEC Cont (Processor), MT, FED- MATCH?-CHECK
A​
03-017
$50​
One Stop Auto Wreckers USA-OR(Klamath-Falls) Request_Quote 1-800-452-1304 Request_Insurance_Quote
Live Chat
2260​
1989
Engine Computer
Ford Bronco II
E9TF-G1A
A​
44865
$Call​
Supreme Truck USA-OR(Portland) Request_Quote 503-284-4171 / 503-284-4174 Request_Insurance_Quote
Live Chat
2272​
1990
Engine Computer
6 CYL,M4SPD,RWD
X​
9M0044
$Call​
Pick A Part USA-OR(Independence) Request_Quote 503-838-4737 Request_Insurance_Quote
Live Chat
2306​
1990
Engine Computer
2.9,5MT,ECM,CKID
X​
ENI308
$50​
B & R Auto Wrecking, Eugene USA-OR(Eugene) E-mail 888-752-1118
Live Chat
Those all look to be V6, price is reasonable...
I'd say you could borrow the one from the '92 I have in the yard but it doesn't run and I have a feeling it's that... I'd offer to check the junkyard by work but it's empty for winter (it floods, they just started emptying it yearly a couple years ago...)
You're in the 4 cylinder section so I knew :), some people just look at current active threads so it isn't always obvious...
I looked at his signature :)
ok, ya got me there... :) I've been bitten there before then I realize I'm one of those people that has 3 rangers on the property, 3 explorers, an F350, two Camry's and an old F Super Duty... sometimes ya gotta make it obvious what you're working on lol
yeah, I have 2 std cab 4x4 4 cyl rangers (one is parts rig) and 89 ext cab 2.9 4x4 daily
This is weird to me. My 91 4.0 harness has a MAF and a MAP. The map is just left open to air as an atmospheric pressure sensor. Now I actually wonder if that could be related to my cold engine stumble on take off when outside temps are below freezing. I had completely forgotten about that. I used the "new" MAP from the 2.9...
???. MAP means MANIFOLD absolute pressure sensor. That would be strange for it to measure atmospheric pressure.
