Found! 1996 manual transmission tunnel cover
Ab_Reed
Forum Member
New England
MA - USA
Other
2021 Toyota Tundra
Vehicle
Drive
3"f 5"r
Just as the title says, I think 92-97 fits? Previous owner (or someone) hacked mine up.
Thank You
Manual or Auto?
I’m blind…. Or old…. Or forgetful…. Or all 3 lol!!
I have one from an Auto you can have (pay shipping) and if it’ll help, I can mark where the factory hold should be cut.
But a cover from 1989-2011 up will work….
Haha best part is I had to double check if I wrote the transmission style or not. I'll look for newer year covers also, but i will keep you in mind. Thank you!
I have one, Ill check condition this evening.
Looks to be straight and solid. PM me if you are interested
I do have another truck with one, but the carpet is still in it so harder to get too
is that just foam thats been ripped out of the middle?
Correct, it was deteriorating and hanging. I can check the other one and see if it’s any better
That foam doesn’t “generally” last long. It is exposed to the elements under the truck such as rain and salt from the roads.
It was used as a sound barrier. You can always spray a little spray foam (and then smooth it out and whatnot) or use a thick rubber mat to replace it.
Perfect thank you.
Ill take the one you posted. Its still much better than mine. How much do you want for it?
Perfect thank you.
PM Incoming
this has been found too
