I want to thank you very much for taking the time to respond to meTechnically, I never did, I just drove it that way, start in 2nd then shift to D above 30mph. I ended up parting it out, made a trailer out of the back half, the engine/transmission went to south carolina, the front frame & attached suspension went to toledo. I suspect it was a band but Im not for sure.
I see you are the only one I have found on the internet who has had this problem, and in the troublesheet I have found that it is a first rate ratch that skidded and that is why it does not connect 1st speed
Before saying goodbye I want to ask you, how long did you use your car this way?
As I see it, either I take apart the transmission to rebuild it or I buy another one and change it, I'm in Guatemala here it's difficult to find a new one, I would have to buy a used one.
Thank you for everything, you are very well and I wish you success in your daily task
