Where do i plug in this wire
D4v1d
Utah
wondering where i plug this wire into the 4.0 v6 and explorer ac blower this wire leads back to my hvac but i have no idea where to plug it in
Is there an opposite wire dangling that seems to fit?
That connector looks factory, but the wire not so much. Can you tell what's on the other side? It kinda looks like the primary ground for the PCM, but I don't remember that having a connector. It just went straight to the negative battery terminal.
It leads back to hvac control
If the vehicle is able to be powered, check the HVAC for what doesn't work. That will give you a start for trouble shooting. Knowing what doesn't work will help point to what component that goes to.
The thing that isnt working is the blower so was wondering if it goes to there and where to plug it in
