ford4wd08
Small update, as I drove to work today, the odometer rolled over to 70,000 miles (I'm fairly certain those are original), regardless, I've put right at 10,000 miles on this rig since I picked it up in 2019.
Not too bad, my mileage has slowed down a lot since my commute went from 30 miles one way to 3, lol, but I still drive the Bronco almost every day and for sure every week.
Couple of small things I've straightened out in the past few months, I finally, I mean finally got the timing set and holding. I did not realize how long the bolt had been backing out and loosening on me on the hold down. I bought a stubby ratcheting wrench from harbor freight and was able to slip it under the exhaust cross over tube and really put some solid torque on it.
I also added the solenoid to the throttle to hold it open when I put the AC on, it seems to be working well, it won't push the throttle open, but will hold it and it retracts when I cut off the AC, so no more dieseling problems like last summer.
Thermostat and radiator are doing well. Really just been enjoying driving it.
I will need a tie rod at some point soon, and have shocks to install on the shelf, but otherwise just putting good gas in it and driving it.
