- May 17, 2024
- Pennsylvania
- 2.5 (4 Cylinder)
That's really interesting. I can't remember driving on the dirt. Maybe when I first bought the truck. But not often and not fast.I sent the pics to a friend who's been in the tire industry for 35 yrs, this was his reply.View attachment 119943
The old method for establishing proper contact patch and tire pressure is to draw a chalk line across your tread and drive on it. See where it wears and where it doesn’t. You want a minimum of 80% of the tread contacting the road. Reduce tire pressure until you achieve it. Really you should do this with any new set of tires.
I run 10 psi in my Choptop tires on the road because that’s what it takes to get 80% across the tread.
That's an interesting "casting blame".... not being hostile, but it doesn't sound like the right answer to me. I've read the professional tire sites claim that as well, but I still don't buy it.
I grew up on a farm, and every vehicle we had drove dirt roads almost exclusively until I turned 14... I could name 6 fullsize ford trucks, 2 buicks, 1 jeep (wagoneer), 2 or 3 ford cars, and so many tractors I can't even name em all (almost all John Deere, but a few Newholland)... never have I seen anything even remotely like that from dirt roads, even during the winter when you are driving on frozen razor blades. When I turned 14, we switched schools to a place 30 miles away and the cars got 30% pave, 70% dirt - still none of that.
It’s not so much a rule as a sort of rule-of-thumb. The bigger your contact patch, the more tire surface available to grip whatever you are driving on, that’s why a lot of serious off-road guys like beadlock rims so they can air down to 2-8 PSI and not have to worry about losing a tire bead. The low tire pressure let’s the tire conform to the ground, increasing traction. It’s less of an issue on pavement, but it’s still an issue.I've never heard of this 80% rule. VERY interesting.
I'll give it a try when I get back home next week.
Additionally, you don’t want too low of a pressure at highway speeds because that causes the tire to flex more and creates heat within the tire structure. Too much heat at high speeds can cause rapid tire disassembly.It’s not so much a rule as a sort of rule-of-thumb. The bigger your contact patch, the more tire surface available to grip whatever you are driving on, that’s why a lot of serious off-road guys like beadlock rims so they can air down to 2-8 PSI and not have to worry about losing a tire bead. The low tire pressure let’s the tire conform to the ground, increasing traction. It’s less of an issue on pavement, but it’s still an issue.
My F-150 I wear out the center of the tread and I accept that as part of the process since I use it to haul and tow a lot, so I keep the tire pressures up to handle that use, but I sacrifice grip on the road empty because of the higher pressure and smaller contact area. I could get more life and better performance out of a set of tires if I adjusted the tire pressure based on being empty or loaded, but without central tire inflation, it’s not overly practical. My Choptop and Ranger since they typically don’t get run as hard, I set the pressure to achieve a better wear on the tires and better traction.
Ideally you would want 100% of the tread width in contact with the road, but that isn’t always realistic, like with my Choptop. At 10 psi I’m barely at 80% roughly and I’m not super willing to try and get more. But 80% of a 12.5” wide tire is a lot of tread on the ground.
You are also lowering your ground pressure by spreading the load across more of the tread instead of concentrating it in one spot, so it really makes sense. Lower ground pressure, more traction, better tire wear.
That’s why I don’t want to go below 10 psi on the Choptop. I think I’m probably flirting with the fine line there. It seems to handle the highway just fine as it sits without getting tires hot. Now that I have a temp gun, I’ll probably do some checking, but I’ve run 10-12 psi for years without any hint of a problem. Of course, it’s also not really a high speed rig, I’ll rarely get it over 70-75 on the highway because it’s just not really intended for that. It’s more comfortable around 65.Additionally, you don’t want too low of a pressure at highway speeds because that causes the tire to flex more and creates heat within the tire structure. Too much heat at high speeds can cause rapid tire disassembly.
Could it be overinflation + worn/bad front bearings? Worn bearings can give some crazy wear, even if the truck isn't driven at highway speeds to make vibration noticeable. If not the bearings, check suspension bushings carefully too. Also, that frame is pretty rusty. Wouldn't hurt to check it while you're looking at the suspension.
several years ago Virginia implemented a statewide speed limit of 35 mph on dirt and gravel roads, and it doesn't have to be posted.
