10" Drum Brake Link PIns
SteveK
USA
Hello all -
I am currently swapping in a locking 8.8 axle into my 2000 Ranger with an open differential. I am swapping the entire axle assembly. The donor vehicle was a 2001 - I am reasonably confident that this is a direct "drop in".
I am cleaning up the axle from the donor vehicle - this includes new brakes and related hardware. The donor axle was from up north, so most of the brake hardware was super rusty crusty.
I have found new parts for almost all of the brake hardware - with one exception.
I am looking for new wheel cylinder link pins. I believe the OEM part number is F57Z-2042-AA.
I can not find these anywhere. The ones in the donor axle were very rusted up and pitted.
I saw some references to Carlson H1414-02, but can not confirm these actually fit.
Can any one recommend a source for these or confirm definitively that the Carlson H1414-02 fit / work?
Thanks in advance!
SteveK
Amazon says they do not fit a 2001 ranger
Auto Value (whoever they are) says they do not fit a 2001 ranger
Ebay says they do not fit.
I’m guessing that you are talking about the pins that go in the wheel cylinder. Those have been unavailable for a long time now to the best of my knowledge. It’s a problem. There’s been talk at times about someone maybe turning out a few but I’ve only heard talk.
Found one thing that claims the Carlson part you reference is for a late 80’s Dodge Ramcharger. It does look kind of similar though. O’Reillys says it also fits a 1975 and similar F-100 Ranger (full size truck).
I've seen a fair amount of rusty brake parts. Polish up the outside of the pins with a wire wheel on a bench grinder then use a file to clean the rust out of the groove at the end. They may not be pretty but they'll get the job done.
I want to say Carquest 1414-2a from Advance Auto has a good chance of working. Reviews say they've fit Ford 10 inch brakes.
Just a guess... so a comparison side by side would be required.
ask and 'ye shall receive,
looks close, will be a snug fit into the rubber end seal.
the slot is wider, and the seal area is not as long.
Howdy - yes, I noted the same thing, but there is a thread around here where a member says he tried them and they worked.... so.. im not sure one way or the other
Noted.. thanks for the response! Actually, I can get these made, but its a "volume thing"... I'd likely need to make like 1000 of them to make it practical...
EXCELLENT!
Thanks for the pic! I would say "yes, these might work"... but it is a "might"... my pins look exactly like your crusty ones in the pic! I blasted them and put them in a lathe to emery cloth them, but they are still heavily pitted...
You cut the part number off...
Are those the 1414-2a?
yes, genuine made in China Wearever brand 1414-2a from Advance Auto Parts.
one per pack, about $6
EDIT:
on the NAPA site I searched for wheel cylinder brake link ( without vehicle ) and found part # UP 80743
For the rust belt states… basically yes…
NH salts the roads so heavily that the pavement is white between storms. I've never seen anything like those pins come off a running vehicle.
