Wiring question
I'm rebuilding a 2019 Ranger xlt crew cab was hit in left front had to replace section of harness have a wire plug that goes under left fender I cannot figure out what it hooks to iI know one goes to fender flare side light the other no clue. Something could have been torn away when wrecked this was a rebuild truck I purchased . Any help would be appreciated.
Wiring question
I'm rebuilding a 2019 Ranger xlt crew cab was hit in left front had to replace section of harness have a wire plug that goes under left fender I cannot figure out what it hooks to iI know one goes to fender flare side light the other no clue. Something could have been torn away when wrecked this was a rebuild truck I purchased . Any help would be appreciated.View attachment 119256
I'm at work in the dark right now. I will run out and see what I can find out when the sun comes up.
All I see is another plug going to the ABS sensor. It plugs in by the top of the UCA. Hope that helps. If not I can pull the liner and see what's in there. I know the battery and fuse box are right above there.
Thanks for the reply sill not sure what plug goes to. My speed sensor goes up steering arm to ucr then plugs in to a plug that goes back into main harness. this was one of the few that wasn't damaged and still was hooked. I've searched hrs on it. I will probably just install everything back and see if i can get a code to tell me what it is. Got battery in today was going to bleed brakes than back right caliber started leaking already did left should have just done both. Thanks again for your time.
