Center console modification/repair
jballard81
Terminal Procrastinater
North Carolina
I've had little luck with a good replacement console when looking at the boneyard. So I figured at least for now, I would fix up my original console.
The aluminum thing that gives it strength was broken.
So I butchered some flat stock into roughly the appropriate shape
It fits in there. Will those little machine screws hold? No idea 😂 hopefully!
Will add some more pics as I get it back together. It was pretty nasty so a good cleaning was required.
I definitely like the price! My seats are about an inch-ish wider than stock buckets so I will def have to measure it out. I'm hopeful I can get the original back together and functional for a little while. Need it back on the road, feels like all I do is fix stuff on it lately 🤣
Update time! It's all back together and feels good. I'm actually pretty happy with how it turned out. Will be good enough at least until I find something better in the future.
First issue: these screws had rusted to where they no longer tightened down in the console:
Nothing some 'adjusted' drywall screws can't fix
Complete for now:
I really can't believe how well the fabric cleaned up. Used some degreaser and then scrubbed it with dish soap in the sink.
I should have taken some before pix of mine... wow... I "saved" a smoker's unit that was rolled and the front windshield was totally smashed out.. just imagine the smell of wet swampy ass cigarettes on the 4th of July after a week plus of late June 100% humidity rains. It was the only SHORT one in the lot that wasn't a 1st gen in way way worse shape (I have a manual - so had to be short to clear the shifter). I wish you and I were closer... between the trim parts you said you have and the fact I could have brought home 3 of the alu center supports last week if I wanted to...
Don't know if it was the roll, general abuse, or a bad design by Ford but one of my feet is broken too... thankfully my brother-in-law has a full service farm that comes equipped with a TIG station... I'm a good MIG guy, but here's to trying my hand at TIG.
I'm teaching myself to weld, but I'm starting very slow. I wouldn't stand a chance with TIG yet 😂.
Wild that the feet broke in a similar way. Maybe it's the strain of having one lean on it from only the driver's side for such a long time?
Regarding the smell, mine was a smoker too. But apparently sat long enough for it to settle if that makes sense? You could see the tobacco brown colored water when I was washing the seats and console.
even if "unbalanced load" were the cause I would call that bad design by ford :P
