- Apr 22, 2021
- Memphis, TN
Hey folks,
The questions I have is anyone else running better than 10BTDC on a stock explorer (98-01), carbureted, distributor..... I have tried for the moon at 16, now to 12 and heading back to 10 for a final test drive.
See below:
I have wrapped up, 99.6%, my 01 Explorer conversion from EFI to Edelbrock Carb with HEI.
Initially I got greedy at the timing light, capped vac advance, initial at 16 degrees and 36 in by 3500 (stock HEI springs/weights). Add the vac and total went to about 46! I pulled about 10 degrees of VAC out (at idle) which tamed it but still it will give 40-41 total at 3500.
It was snappy in the driveway, awesome.
Put a load on it and it is unhappy of course. I anticipated it but was hioping for a miracle.
87 octane only, I will not run anything better. It is a grocery getter....... built for highest reliability.
So I pulled it back to 12 initial, with vac its at 22 or so and all in at 3500 is still about 41
Pinged a ton less but really not happy under load at WOT. Like hit it and lift just as fast in dreadful fear.
I am going to pull initial back to 10 where Ford set it. With EFI that engine ran on baby oil mixed with urine and did not ping, although not as snappy as it is right now! I love carburetors--- throttle response is awesome.
I may be able to get back a couple of degrees both in VAC and initial once I have the Wideband installed. I had one hit at 12 degrees, just one. I had a bog, like a lean bog, and then the ping. I believe that I am weak on enrichment.
But as well I think the transmission shifted somewhere in there due to far from optimal shift curves. I need to ELIMINATE timing for a week until I can get the Wideband and some measurements. It will be hard to tune the transmission with funky ignition and funkier fuel.
This is a stock 1905 Carb, Mech choke, tuned to 22.5 in HG vac for idle (max lean/max rpm/max vac). I have performed zero tuning as until I get a reasonably safe timing set, it is too difficult to deal with fuel.
As well last night was the first test drive on a Microsquirt TCU. Trans controller programming and function trumps fuel and ignition ever so slightly for priority.
So all that is backstory for the vehicle. The question remains, is it likely that 10BTDC is all I will get out of the Exp engine on 87 or is there someone who can testify to a bit more (given fuel is perfect!).
This is not a request for a fix, just for feedback on experiences.
Thanks for the read and sharing your experiences.
See below:
