- Dec 10, 2021
- Washington
- State - Country
- N/A
- Other
- 2023 Taco
- Drive
- 4WD
In this picture here, you can see where the front and rear frames join if that's what was needed.
Well the rear or back frame seem to be fine and fixable.In this picture here, you can see where the front and rear frames join if that's what was needed.
Shhhh…. I’ve overloaded the ranger a few times and I don’t want to think about any damage I may have done. But she drives fine so I’m not sure it did anything.a 3/8 drop on the left rear chassis, probably due to overloading
If the back is bent just little bit, when the bed was put on the back bolts were probably tightened first which would cause the front of the bed to raise.But the only thing that i am wondering about is the slight cabin elevation.
It looks great...Thank you... I really appreciate this...Just finished up the repairs, I pulled the frame up on the left rear past where it needed to be, taking out the tension and relaxing the frame with a BFH.
I fabricated some 3/16 angle bracing above the rear axle and bolted it to the frame both sides using existing holes that were drilled for an extinct air spring assister.
Also added a cross brace from one side to another. Nothing fancy butView attachment 117324View attachment 117325View attachment 117326View attachment 117327 has stiffened it up.
Nicely done.As she sits now after a drive over a bumpy road.View attachment 117343View attachment 117344
