Project “Fat B!tch 2.0” is officially underway!!
No updates today…. Had to pull a 12 hour shift at work.
Nothing new today. Still Jackstand wheeling.
Got on eBay last night after work and bought a 91 Ranger and 97 Explorer EVTM manual. Both should be here this week and then I’m gonna start my harness splices.
91 Ranger EVTM showed up yesterday, and today, I went and harvested a 2000 Mountaineer engine bay harness at my local PAP.
Guess I’ll start figuring it out from here….
Nothing new today. Still waiting on my 97 EVTM to show up.
Thinking of harvesting the inner fenders from my 03 parts truck so that all the air box and such will fit where it should.
How hard would the fenders and such from the Gen II be to make fit the 03 inner fenders?
Sat down and started figuring out what all the pins go to on my 5.0 engine harness.
Particularly connector # C115F. It’s the big black square connector that is the only connector that doesn’t plug into the engine or transmission.
this is the easy part. remembering this shit two years from now out on the trail with no cell service is where it gets frustrating....:woot::buttkick:
I thought of the same thing. I will most likely write it down or draw a rough sketch of the “made harness”
I’m deleting a lot of things like A/C and stuff… so hopefully it won’t be as bad as it may seem.
I’m back….
Had to step away due to life, work, and deciding a few things about my build.
Nothing had changed, but I may change the body since I didn’t do anything really to this one.
Just swapped Bronco II for a 92 ext cab that had a 3.0….. so even my wire harness will still work.
Anyone need some gen 2 3.0 stuff?
A few things came together today in preparation for the build.
-Sold a bunch of Gen 3/4 body parts to clear some space and make a little money.
-Cut 6 6x6x15 block to set my jack stands up on to gain a little height. I will need 16 of them (4 per stand), so a little more cutting to do.
I’m in B’ham AL, so if anyone wants to come by and help, or shoot the breeze, PM me and I’ll send my address…. Who knows, you may even find a few things in my stash you could use….
Stripe (he’s a good boy) cut the rest of the block today.
Tomorrow we will see about getting the truck up on the stands and beginning to remove the suspension.
Anyone need some stock 2wd beams?
  • Project “Fat B!tch 2.0” is officially underway!!
Definitely needs some bigger rims and tires!!
Started lifting it onto stands today…
Phase 1…..
Finished product.
Wife was NOT happy with how “sketchy” this process was!! (I’ll admit, it was hairy for me at one point also.)
Needs leveled front-to-back
And side-to-side….
I’ll knock that out tomorrow.
