- Feb 24, 2024
- North Carolina
- 4.0 V6
So just finished replacing the engine mounts and started the engine and it's sounding rough. Making an almost chirp like sound from the front near the fan. The tensioner is getting a workout. I'm guessing that a pulley bearing or bearing inside the alternator (that seems to be where the sound is the worst) is going out. I'm going to post a link to a short video. It kind of looks like the belt slows down at some points and it's bogging down the engine.
Here are the check engine codes:
565 - canister purge 1 solenoid failure
556 - fuel pump relay primary circuit failure
629 - torque converter circuit failure
566 - transmission 3/4 shift solenoid/circuit failure
This feels like a pretty odd mixed bag codes. Especially since it runs and drives, albeit running rough. The transmission codes are throwing me b/c it ran through all the gears smoothly yesterday when i took it for a test drive.
I will get under it and see if lifting the engine disturbed some connections... Any feedback would be appreciated!
Link to video
Thanks!
Link to video
Thanks!
