- Apr 30, 2024
- Moncton NB
- 3.0L
I did forget that this was a repurposed car engine when I first posted... Makes sense. I've been thinking about a relocate kit since the first oil change I did on the truck.I think the 3.0 was originally intended for the taurus chassis & then made its way into the areostar/ranger platform. Its not bad to change in a taurus, in fact you can even put the larger FL-1A filter on. Not in a ranger chassis though! Im not sure if there is a filter relocation kit that would work, but Id go that route myself if I had that engine.
The big problem doing mine is that in going through all the contortions to maneuver the filter around and into position, I always manage to bump it up against something dirty or rusty, usually the manifold, which risks dumping rust flakes into the filter, which is what happened this time. IIRC, Yes there's a way to insert it into position with the holes down, but that requires a one-handed 270 degree flip with another 90 degree flip to get it lined up... With greasy hands/gloves, and usually a warm manifold. In fact I still have burn scars from the previous time and I was wearing gloves.Yes it's one handed I tried from the bottom I'm very thin too and that didn't work, so I just roll it down until it plops through, it really tested my patience at first
Haven't thought about it but I wonder if I just removed the drip pan would it fit through the bottom.
If you go from the front near the exhaust between that and the steering you'll see it will barely roll through against the starter. Just nudge it through and keep the threaded part facing where it needs to be, but lining it up is hard because it's angled on the block on mine not a straight connection.![]()
I guess I need to wire brush everything before I do the next change.
