01 Ranger Towing Abilities
Daltoids
Forum Member
Louisiana
2.5 (4 Cylinder)
Take time with a wounded hand
Hey again, so recently I've wanted to start a lawnmowing business with an old lawnmower my grandfather has no use for anymore, and I need to know the towing capacity/abilities of a Ranger with the 2.5 and 5 speed. Surely it can't be high. All im really gonna plan on towing is a small trailer and a ride on mower.
This is for the 01 Ranger
if your truck is a fleetside, i would just get ramps and drive the rider into the bed instead of hauling a trailer around. even a small 5x8 trailer can be a bummer in some places.
thats what i have, a small 5x8 trailer that is used to take stuff to the dump and pick up stuff from the hardware store
getting the trailer moving won't be an issue, stopping will be noticeably longer.
you will spend more time in lower gears, no big deal.
2011 pretty much covered it as did pjtoledo. The only thing I'd add is don't use 5th gear while towing. Expect longer intervals between shifts and stop sooner than normal. It will take a bit of getting used to before you'll be able to gauge when you actually need to brake and not pass where you want to stop. As mentioned above, getting going usually isn't the problem. Stopping, especially when going down hill, is another story.
And please, if you get a trailer, make sure you do the hitch right. I don’t like using a bumper to pull anything, put a class 3 hitch on and set the hitch so the trailer sits level when everything is loaded the way you’ll run it. I see way too many people that have mis-adjusted hitches where the trailer is either nose down or nose high and neither is good. The other thing is weight balance and tongue weight. Improper loading of a trailer in other words. Too much or too little tongue weight will contribute to trailer sway
A riding mower on a small trailer?
You'll be fine.
I tow a 750lb ATV on 800lb trailer all the time and its no sweat..
I have an 87 with a 2.9(V6) and a 5 speed. But with a 3 or 400lb mower and a tiny trailer youre probably not even over 1000lbs.
You could tow that with a focus.
Thanks for the replies guys! This helped a lot :blush:
You'll be fine.
And the 2.9 hasn't thrown a rod yet?! Impressive!
it depends.....
is it a ford ranger?
or a ford f@#$%^!G ranger.
if its a ranger...your good to go...
if its a ford f@#$%^g ranger...... it will pull a planet.....so yeah...good to go.
just sayin. good to go.
From what I've compared a Ranger especially an older one doesn't make any sense on paper.
In reality it can keep up with my wife's F150 supercrew with a 4.6 OHC V8 and Automatic.
Right now my 3.0 OHV V6 5 Speed manual on paper should be at a disadvantage, but they are surprisingly close!
Since your low revving if it's a Pushrod, well that's where you wanna be!
The 4.6 OHC mimics a OHV but it still has to REV for a second before anything actually happens plus it weighs more so that helps when rolling.
Previous owner F@$&KED the bumper on mine and it has TWO balls on there 😂
Will you be slower? Yep but you'll still be chugging along like the little engine that could hell I never driven a 4 banger Ranger but everyone I talked to said they could haul WHATEVER to the point it was a GAME a JOKE.
Don't be a stranger...
Unfourtantly physical ability doesnt matter to law enforcement.
Only fords stupidly low numbers.
That and that most new "trucks" today are dangerous and too big that it actually takes away from being useful.
The F150 we have has SERIOUS blind spots due to its extended cab.
Hopeful this trend is coming to an end, people simply aren't buying new vehicles regardless 😕
If anything people are buying older gen vehicles everywhere, and that's a good thing.
You cannot see a pedestrian at all in a new F150 and the "mid-size" like Ranger/Colorado is a joke.
They are bigger than what a full sized truck was in the 90s and didn't function the same.
Absolutely hated the new Colorado build quality was crap and it didn't seem to matter your size or height, everything was uncomfortable and the bed itself was still to high.
Same goes for the new ranger, it's being targeted at a different demographic yet everywhere that a actual truck is needed, usually it's the older gens outnumbering the modern ones.
At least the wife's has a 4.6 and a extended bed, but you really have to be careful around people the beams block everything, no camera or mirror will fix that and then it's being marketed as "safer" which is false information when you look at crash testing they do HORRIBLE.
Trying to reach into her bed is impossible I'm 6'1 basically 6'2 with boots, it's stupid..
The wife's 1999 bubble body extended cab/bed with suicide doors was still smaller than this 2010 and shorter, more capable, less hood height still had presence and you could see damn near 360 degrees. Even with her being short she could even reach into the side of the bed 😂
We were at a red light, someone ran a off ramp thru the intersection underpass, it saved not just our life but took the blow saving the other vehicles next to us because it absorbed ALL the shock from a airborne SUV.
It was the only vehicle to still drive on it's own power.
I still remember pulling a child from the SUV, crazy.
I had an 08 colorado W/T from 08-15. It was similar to the older rangers for useabilty as you mentioned. Athough it didnt seem nearly as well built as the rangers ive had.
Either way when i bought my grand cherokee i looked at a few of the newer colorados, and yeah, i didnt like them for many of the reasons you said. Plus the way they were priced i might as well of just bought a friggin silverado.
I drove a few of the 15+ F150s as well when i was looking, and compared to my 97 F250 (OBS) they were hard to see out of.
Any post 2010ish vehicle ive been in has had massive blind spots. They all feel like youre in a cacoon with windows.
The big thing when towing, especially with a ranger is getting stopped. My ‘94 2.3 didn’t do too bad pulling, especially after adding a 4.10 rear but getting stopped with a heavy load was another story. I know theres many factors that go into a tow rating/ability but remember getting it moving is only part of it, gotta get stopped too. And if a situation comes when you have to panic stop, you could be in trouble. and johnny law only cares about what the manufacturer rated it for, no matter what upgrades youve done.
