1991 ford ranger 4.0l with 92 explorer ecm
Bodie1991/4.0
Firefighter
Washington
Hey everybody my name is Bodie and I’ve been driving rangers since I was 16 my first truck was a rusted out 92 2wd 2.3 kinda butchered that truck and feel pretty bad about beating on it as much as I did but I digress my new project I’m working on I’ve been flying solo for about two years just trying to work out kinks and I’m stumped thus joining trs I have a lot done to the truck so I’ll have to explain further if anybody is willing to help my now truck is a 91 4.0 factory 4x4 I’ve sas’d it and replaced the ecm with a 92 explorer ecm because in all of my 21 years of wisdom I left the battery plugged in with the key on while welding on the truck🤦‍♂️ so what I got going on is I can’t get it to rev above 3000 rpm and I’ve replaced the tps, map, iacv, air intake temp, coolant temp, and checked all of these things prior to replacing most of which were fine just dirty so those went on the shelf. Back to the list I’ve also replaced the fuel filter and tested for pressure all good there as well I’ve supplied pin 30 with 5v from pin 26 and the rear axle I put in it came with a wss not sure on condition but it out of a dodge so I don’t assume it works. Lastly I put the nss on three switches so I can turn it on and off for testing nothing has seemed to work any help is appreciated thank you for reading
So everything was fine. Then you replaced the ECM and now it will not run above 3000? Looks like you need another different type of ECM?
Here are all the different ones listed for a 1991 Ford ranger. The ones at the bottom are for a 4.0.
Electronic Control Module, (behind RH kick panel), 4-140 (2.3L), AT, ID F07F-AEA
Electronic Control Module, (behind RH kick panel), 4-140 (2.3L), AT, ID F07F-BB
Electronic Control Module, (behind RH kick panel), 4-140 (2.3L), AT, ID F07F-BC
Electronic Control Module, (behind RH kick panel), 4-140 (2.3L), AT, ID F0PF-MA
Electronic Control Module, (behind RH kick panel), 4-140 (2.3L), MT, ID F07F-AB
Electronic Control Module, (behind RH kick panel), 4-140 (2.3L), MT, ID F07F-AC
Electronic Control Module, (behind RH kick panel), 4-140 (2.3L), MT, ID F07F-ADA
Electronic Control Module, (behind RH kick panel), 4-140 (2.3L), MT, ID F0PF-LA
Electronic Control Module, (behind RH kick panel), 6-179 (2.9L), AT
Electronic Control Module, (behind RH kick panel), 6-179 (2.9L), MT
Electronic Control Module, (behind RH kick panel), 6-183 (3.0L), AT
Electronic Control Module, (behind RH kick panel), 6-183 (3.0L), MT
Electronic Control Module, (behind RH kick panel), 6-245 (4.0L), AT, 4x2, ID F07F-L1A
Electronic Control Module, (behind RH kick panel), 6-245 (4.0L), AT, 4x2, ID F07F-LA
Electronic Control Module, (behind RH kick panel), 6-245 (4.0L), AT, 4x2, ID F17F-ACA
Electronic Control Module, (behind RH kick panel), 6-245 (4.0L), AT, 4x4, ID F07F-M1A
Electronic Control Module, (behind RH kick panel), 6-245 (4.0L), AT, 4x4, ID F17F-ADA
Electronic Control Module, (behind RH kick panel), 6-245 (4.0L), MT
I picked the F07F-M1A and these came up in Washington state.
1990
Engine Computer
(ECU), 6-245 (4.0L), 4X4, F07F12A650MA
A​
K04373
$75​
Gerry's Foreign Auto Parts USA-WA(Kittitas) Request_Quote 509-968-4466 / 800-848-5578 Request_Insurance_Quote
Live Chat
2166​
1990
Engine Computer
Electronic Control Module, 6-245 (4.0L), 4x4, Federal,4.0L,AUTO TRANS
X​
1IK029
$50​
AR1 Auto Parts USA-WA(Yakima) Request_Quote 866-270-3221 / TEXT 509-452-0818 Request_Insurance_Quote
Hey man thanks for all the help I’ll look into those as an option and get back to ya I’m also in a general discussions thread trying to figure it out this list is very helpful though
Where did you get this listing? I am currently in the process of swapping in a 4.0L OHV from a 1996 Explorer into a 1990 Bronco II. My intent is to use an ECU from a 1990/91 Ranger because *i think* I should be able to plug the ECU from the 90/91 Ranger into the BII's ECU harness and be good to go with the 4.0L OHV engine.
From www.car-part.com
