- Aug 17, 2007
- central ohio
- 2.5 (4 Cylinder)
- Tire Size
- 235/70/16
- My credo
- the grey-t escape
Thinking of trying it out, the chinensuim 4.80-8’s on my yard cart wont hold air, only 2 years old and not rotten so tubes must be bad, I first thought of trying to source hubs so I could use some extra golf-cart tires I have but seems like more $ & time than the whole dump cart is worth. Then I had another thought- spray contruction expanding foam. Drill a hole in each tire & exhaust the contents of the can. Maybe $6-8 a can ? so for less than $20 my cart can be useable again for more than 30 min. The cheapest solid wheels from tsc are $54/wheel. That will be my next choice if the foam thing doesn’t work out. Axle shaft size on this cart is 3/4” x 3” long, If it was longer my original wheel horse steer tires would work. Kind of limits me to the narrow “wheelbarrow “ stlye assemblies. Oddly enough I didn’t use my yard cart that often. But now with the chicken house I need it about once a month for clean out.
