2007 Ranger XLT Limited Edition
Kenora Ontario
I’m having some kind of electrical issue, when I try to start my truck, my instrument cluster only shows the red lock/truck icon. Fan and lights work fine, and on occasion is will all of a sudden start when turning the key. Battery and alternator are fine !
need help !!
Are you getting an audible "click" when you turn the key to start?
Have you tried wiggling the gear shifter... or try starting it in neutral?
Being it's intermittent... I would ensure you have good connections at the ignition switch.
I moved this to the electrical forum... FYI
I also have a factory Wiring Diagrams manual for my 06. If you need them I can post you some info.
As a follow up on the electrical issue of my 2007 ranger XLT. Turns out it’s the control body module, and the manufacturer no longer makes them. Now the search to find one.
