I swapped a manual transmission in my 1990 ford ranger 4.0 sxt and I'm having trouble with the wiring please help. Tha k you
Which wires? Maybe pics would help...I swapped a manual transmission in my 1990 ford ranger 4.0 sxt and I'm having trouble with the wiring please help. Tha k you
Did the engine run fine before you put the manual in?. Also they key doesn't work i have to jump the ignition relay to start and still it will crank sometimes but run horrible and backfire out of the intake.
Did you use the engine with the automatic after it was rebuilt?Its a badass truck the motorr was just rebuilt its Makes crazy noise out of the intake
Yes the automatic before I put theAre you referring to an electric shifter?
No see I also have a 2001 transmission thats wht I wanted to put in it at first but I put the 2004 in e everything bolted up just fine e just do t know electricalDid you use the engine with the automatic after it was rebuilt?
