Junk Collector
⭐Supporting Member
Truck of Month
Two boxes of stuff - cover the shipping from me to you and they're yours.
Box #1 is a partial wiring harness/carb/distributor/smog pump and other associated pieces that were removed from an '85 Ranger for a Duraspark swap
Box #2 (not pictured) contains an A4LD shifter assembly from the same truck that was removed when I swapped in a 5 speed. This is the 4x4 manual shift variant. Good condition.
Hate to throw this stuff away. Figured someone in states with smog checks might need box #1, this stuff can be pretty hard to find.
