2.3L ('83-'97) Drilled out ignition key!!!
Final777
Im trying to figure out if i have to remove my entire steering column in order to fix the ignition switch and actuator pin. It has a drill whole all the way down the ignition keyway and the turning gear inside the key ignition is gone. I'll send a pic along with it, I'm not a very experienced mechanic so u don't want to have to pull the entire steering column out if anyone at all can help please respond back ty
You can replace the gear and cylinder as long as the part the cylinder slides into is OK
If "they" messed up the cylinders mounting hole then yes, another column from wrecking yard, not sure there will be "new" parts
Here's a pic
Bummer
I am pretty sure you can't use that again
Good website to find used parts: https://www.car-part.com/
1985-1988 Ranger or BII will work
1986
Steering column
USA
Sort by distance
YOUR Zipcode
Search
New window opens
4 selections, pick the one you want
Search
Any with a Picture click on picture several pics will be available if that one truck
Thanks i appreciate it I've bought from them before but i have 3 other rangers as well and one Is just for parts. I'll just have to do it myself and that one is something i have never attempted, but it don't look all that easy thank you so much for your help!
The easiest/quickest way I’ve found to remove an ignition switch without the key:
Take a big, old school Craftsman screwdriver with the square shank and hammer it into the lock. Take a big adjustable wrench and force it to turn to the run position.
Push in the release pin and remove the lock cylinder.
That looks pretty bad. Someone attack your Ranger?
