Which is also why they are an improvement over drums in most pickup towing duties.
Are rear discs needed on a Ranger? Not normally.
Is it worth upgrading a Ranger to rear disc just for the sake of getting rear discs? Probably not.
Is it worth upgrading a Ranger to rear discs because it's accompanied by larger 31 spline axles, a limited slip differential, and wider track width? Possibly depending on your planned use.
Is it worth upgrading a Ranger to rear discs because you want to? Absolutely!
Both my Rangers will likely end up with rear discs. Mostly for the latter reason.
The 99 will get an Explorer disc brake rear axle from the V8 swap donor, or maybe before since I've got one already. For my planned usage the larger axles, the limited slip, and wider track width will also be beneficial. The front will also end up with the slightly larger front brakes from a later truck.
If I can find one the 85 will probably get a 10-11 rear disc axle to go with upgraded front brakes. Almost solely because I want them and they'll look better behind some open spoke wheels than the drums would. Don't really need the 31 spline axles in this thing since it has, and will likely keep, the 4 banger (possibly with boost added). I think that it would be a better fit than the Explorer axle because it isn;t quite as wide, the Ex axle is almost too wide for a first gen. Almost. If I don't find one, I'll use the spare Explorer axle I should have by then. At this rate it'll be a few years before I'm ready to build it, so plenty of time to acquire what I want.
