- Apr 24, 2020
- Kintersville, PA
Floor mat question, for the Road Ranger, 97 extended cab XLT (and I have learned to search the site before I ask such questions):
The new carpet is just beautiful and I’d like to keep it that way as long as possible. It’s mostly a driver, but I do occasionally work out of it. I’d like to get the Weatherguard tight set-in-place floor mats that protect, but don’t shift around as you get in and out. I have to put the OEM floor mats in my F250 in the right place every time I get in, makes me crazy. Whetherguard doesn’t have a specific for that model, only the cut-and-fit yourself ones.
Does anyone know of a rubber or carpet or combo floormat that fits in place that doesn’t shift around for that truck? I’m open to a trim-down (like Weatherguard offers), but I want something more substantial structurally that’ll stay in place better than weatherguard offers.
My other thought is to pull the two bolts from the front of the seat, replace them with threaded studs and a nut to hold the seat down, but with the threads protruding so I can put them through whatever carpet piece I get and bolt the mat down. I could buy something generic, oversized, or just get a piece of appropriate carpet. I would run some kind of a strip along the edge in the rear so that it’s holding by more than just the two bolts spots.
I’m open to any other ideas like that so I don’t have to adjust it every time I get in and out of the truck.
Help! All contents and suggestions welcome
Husky makes a set of of molded rubber floormats for the rangers that have the spikes on the bottom so they don't move around. Work well I have a set.
https://www.huskyliners.com/?fitment=1
The molded floor mats tend to be much more expense then the generic cut to size ones, but they fit perfectly and don't move around. Plus they tend to have raised edges so they collect any water instead of running over into the carpet.
Husky tends to be less expensive then weathertech, but not $20 wally world cheap.
