I have noticed a rather fierce noise from the right side with the hubs locked in on the highway. Leaving the roundup last year it did it and I had to pull over as I couldn't take the noise and then again this year after I put the front driveshaft in I forgot the hubs locked in (used the lockouts to lock the front diff to keep things from turning) and it did it again. Won't do it in the cab with the hubs unlocked and the t-case engaged for some reason.
Its been bugging me and with the big Vagabond trip coming up I gotta get this thing as good as I can get it. So I had the brainy idea of putting the rear in neutral and putting the front in gear with the hubs unlocked to see if I can hear anything at all outside of the truck.
And there it is, maybe with the t-case engaged to the rest of the drivetrain it can't resonate or something I dunno.
So I rip the front wheel off and dive into it.
Spindle bearing is still greasy and the seals were assembled correctly.
However the shaft has seen a better day.
Its been a couple days ago too, after consulting my historical archives it was like that when I put it in. Not sure if I didn't notice it, thought I would just try it and see how it went or what. Its been in the truck since 2019 but with no front driveshaft I only ever really used 4wd on TRS trail rides once a year... until now.
I even went back to when I did the swap in this thread and I don't say anything about it so I guess we shall never know.
I had started a
thread about the axle noise in the axle section,
@pjtoledo questioned my wheel bearings about if they had maybe spun on the spindle. And there was a little wear on the bottom of the spindle. So now I need a spindle and new wheel bearings. But that can wait a bit...
So ok fine, between here and there I have picked up a spare shaft, everything on it looks great so after a little debate I decide to throw a new cross in it (didn't really feel that bad) and just swap shafts. But wait, more drama around every bend! The friggin telescoping part of the shaft is full of mud and seized.
So I soak and beat and soak and beat and get that apart.
And then I have to salvage the spring from hell off the old shaft. Major PITA, very rewarding to think for this thing to be a functional spare I need to get another spring and put it on as I am not dealing with that in the field. -5/10, do not recommend.
So then I go to slip the new cross in into the new-to-the-truck shaft... looking a little parched in there.
Probably the easiest thing I did today...
Anyway to recap, if I did it right I should have used a different axle stub shaft way back when I wouldn't have had the noise. But if I didn't do that I wouldn't have been dragged into this thing deep enough to know that the two axleshafts were seized together, and I almost just noted the worn shaft to come back to later. I had been intending to pack the bearings but without the noise I wouldn't have started the thread and gotten the info about why the grease was different colors.
This came across my FB feed last week, awesome quote and as I was in a battle of wits fight with a steel stick and losing it struck a cord with me.
