- Apr 24, 2020
- Kintersville, PA
Nice spring pack you got there.
Definitely an awning and solar panel. Canoe/kayak carrier... shower awning... ladder type tree stands.
I've been looking at the flexible panels and they don't really require any frame structure.
I even saw people use a section of 4 inch black PVC with a fill port and a spigot with shower head. The black pipe will warm the water. 4 inch x 7 foot would give you about 5 gallons of water. Enough for a couple quick clean ups.
Leave the ladder racks. They are just too useful. If you find they're not, then get rid of them.
That's how I see it, too. How does the ladder rack mount to he box now? I would be looking at making the rack part easy and quick to remove and reinstall, without compromising its load carrying or structural integrity. Make it almost like a quick-change accessory.
High drilling speed kills hole saws. The teeth (only) are tempered; if the saw gets too hot the temper is affected and the teeth will dull quickly.
Keep the drill RPM down, or you can pulse the trigger, but I suggest that you use a drill with a second handle for better control. You can also use cutting oil (any light oil, really) to help the cutting, keep the saw temperature down, and to help prevent chips from sticking to the teeth.
Drilling aluminum will be easier, but do keep the speed down and use oil.
Good move, on getting the lighting and its electrical harness squared away first.
What are you planning for ventilation?
You'd have to think with the doors closed to keep the bugs out... that thing is gonna be a sweat box on a warm summer night.
I kinda think I would want a couple windows too.
I would suggest running a 5-wire or 7-wire for brakes and backup lights.
Possibly providing some power for other things as well but keep in mind that the amperage isn’t super high and not all of them have power all the time, at least as the wires are normally setup.
I've never been a fan of the tires poking out of the fenders look. In some states, they can actually give you a ticket for it. Though, it doesn't seemed to be enforced much. Perhaps they save it for when they really want to pile on the offenses or get you for something but can't find anything else that would stick.
In any case, I think fender flares can look great and if you can work a step or two in them to make them even more useful, bonus.
As a side note, most of the more aggressive tires tend to make great rock throwers. A set of mud flaps might be a good idea. Mud flaps aren't everyone's thing but if you are riding in a group, the person behind you might appreciate them being there.
As far as clearancing the wheel wells, it looks like that would be a good idea. There doesn't appear to be much room up front but it might be ok with some finessing. There appears to be much more room on the back side to play with.
