- May 15, 2020
- Age
- 70
- Atlanta
- State - Country
- GA - USA
- Other
- Manufacturers factory tour, maybe big dealership tour
- Vehicle
- Ford Ranger
- 4.0 V6
- Total Lift
- 97 stock, 3” on 87
- Total Drop
- N/A
- Tire Size
- 235/75-15
- My credo
- Never put off ‘til tomorrow what you can put off indefinitely
Who’s stupid idea was this?
I got all the wires run from the toolbox forward. There are still a few to run to the rear end when I pull the trailer off.
I didn’t have enough different color wires so I had to run two browns to the front and two browns to the back. Of course, when I started to wire it together, I had to guess which was which. Typical of my luck both were backwards, but it was an easy fix.
After I got all the wires where they belong, I got as far as hanging that gizmo, and hanging the CB off the bottom of it. I’ll be damned if the antenna wire doesn’t get in the way of the mirror mount, so I modified it 10 times so I could still adjust my mirror, and I’m still going to have to remount it an inch lower.
one step forward…..
….and then this on the other end of the same door:
Acetone trick seems to have worked on the other end, so we’ll start with that tomorrow.
one step forward…..
