for polishing round stuff I use a wide flat boot string coated with polishing compound.
crocus cloth, a type of emery, is also good for polishing.
I finished the oil pan gasket and rear main seal on Friday and the clutch and transmission rebuild on Saturday.
I was able to use a chain hoist and transverse engine bar to sneak the oil pan out. Drove it today for @100 miles and no more leaks. Shifts like a dream.
That sounds about right… I’ve had full intentions of fixing something 100% and then I won’t have to worry about it again for awhile every time I’ve taken something out of service and they usually end up 70-90% done and pressed back into service because something else broke and I now need what I was fixingRefresh me a little. This is fun? A hobby, Right? We do this cause we like it, right?
In the last week half my junk pile fell apart while I was working on the other half. It always happens when I take one or two out for upgrade or service.
I dropped the tranny pan on the 87 Town Car to flush out the old fluid and add a drain plug for the next time I do it 10 years from now. I also took a couple things off the top of the engine to swap out all the plugs and do a general tuneup. So, of course, the AC went out on Ole Blue (88 Town Car). Pulley started screaming like a Halloween banshee. I haven’t checked if it’s just a clutch or if compressor locked up. Thank God it lasted till after the hot weather.
The Missing Linc is pulling a little bit to the right, and I noticed the right front tire wearing a little bit on the outside. I got the pinion seal, but haven’t replaced yet, and I’ve got a list of two or three other “have to” items. I want to at least rotate the tires, so I don’t ruin the one, and then get underneath and figure out what’s going on up there.
Ditto, I started to change out the fuel filter bowl on Big Red, and you know I’ve had the whole interior out of The Road Ranger to finish up the wiring to the accessories.
It’s all about careful planning. The 78 Mark V is running like a top, but of course it’s parked behind everything else, and I can’t get out it. It’s going to be a busy week…
