Just made my wheel checker… now I just need it to stop raining…
The welding rod "trick" just shows clearance, it doesn't show you king pin axis inclination.
p.s. if you put a couple extra bends in your welding rod, you can mimic the tires you intend to run as well. And whole wheel clearance is probably just as important as rim clearance.
Note: The welding rod test doesn't show if the dust cap will extend beyound the rim, which is often the issue with Mustang rims on Ranger. But as @stmitch noted, 12 to 15mm spacers usually "solves" that issue.
As you are 2wd/thinking of minor lowering, you most likely won't have an issue with contacting suspension components/sheetmetal - Ford designed the Ranger to have lots of clearance with 265mm wide off road tires. So, if you're 285mm or less for tires width in front, you should be fine (you can get crazy in back with tire width (@JC4x4trucks ran T-Bird rims with 40mm offset in back without spacers and had no issues with 225mm wide tires contacting springs/box)
Thank you for the link! I’m going to order them right now, I figured the back studs were going to need to be trimmed because I noticed they were alittle longer in the back, almost sticking out of the lug nut before I removed themThis is what I bought: https://www.ebay.com/itm/264865316090
Get the ones that are hub-centric, they result in way less issues with not centering up the wheel. And to whomever said I needed these because I have larger center bores, that is incorrect - it is the same center bore as a Mustang.
When I put the 1.25" thick adapters on my Ranger, the front studs were perfect, but I had to trim a little length from the rear axle studs to avoid having them hitting the wheel mounting face.
The ideal with putting on different wheels is to have the center of the tire stay in the same place as factory. That means if you add 2" of rim width, you want to add 1" on the outside and 1" on the inside compared to the factory wheel. That will cause the kingpin angle to remain correct. If you put the center of the tire in a different location (inboard or outboard from factory) that makes the vehicle want to wander on ruts in the road. Since nearly all roads have small ruts or depressions where the majority of traffic runs, it makes it harder to keep the vehicle running straight. All of what I just described applies if the outside diameter of the new tire is the same as the factory tire. If you put larger diameter tires (33" v. 30" for example) then the new wheels need to be outboard farther so the kingpin angle still meets the ground at the center of the tire.
That sounds good.
A 9” wheel is computed as 10” wide when figuring backspace etc. (the lips are the extra inch)Fooling around with some math…
the 18x9 has a 5.9 back space.. which gives me a 3.1 front space
factory 15x 7 wheels I have on the truck now when I measure come up with a 4” front space
if I add a 1 inch adapter it should bring the wheel out to almost the factory front face.. just curious if that now 5” back space will have clearance
again.. won’t be able to tell until I have this wheel in hand
having too much fun thinking..
Thank you!! I just purchased a set!I have used these on a few vehicles and I really like them and recommend them: https://www.ebay.com/itm/303853066533
