I don't think so, I believe 93-2011 interchange but not the earlier ones. My friend is closing up his used car dealership, last I knew he had 3 Ford bedliners for your truck,after I took one for mine.I have a 2002 Ford Ranger XL (white truck)with a 7 ft. bed. I recently found a 7 ft.bed liner In a 1992 Ranger XL (red truck). Will it fit my 2002?
1983 to 1992 beds were 2" narrower than 1993-2011
My 87/88 whatever it was had a bed mat which fit perfectly, and when I got the 93 I moved it over. It was a good bit longer, rolled up a bit in front, fit the wheel wells, fit the sides, and rolled up a smidge on the tailgate, which is absolutely no problem, it doesn't hamper me open or closing the tailgate.
That rear gas filler thing doesn't exactly fit right either but it doesn't bother anything
True, but I think the 93 bed is as long as it gets with the supercab. The 87 was a short cab, long bed. It fit the 93 well enough I just decided to keep it.
My 88 was a long bed, my 93 is whatever came with a supercab.There were only two bed lengths available prior to the reintroduction. 6 foot short bed and 7 foot long bed. All extended cabs came with the short bed. Regular cabs could come with the short or long bed, but you said yours was long. As I said sounds like short bed vs long bed.
I can't say exactly where the 12" was added, but IIRC the wheel base on the regular cabs was 6" longer, so likely evenly split to the front and rear of the bed. So if your liner were centered on the wheel wells it would be approximately 6" too long to the front and rear of the bed.
I wouldn't use one of those if it was free, they trap moisture and rust the bed out underneath, had 3 trucks that did that, spray in bedliner is the way to go.
