So here's the rules- you have 10 grand to spend and the apocalypse is upon us.
What would you build? Why would you build it that way?
I want to hear about the different functionalities and gadgets, whether you'd go full on gas guzzler or economy engine. Lexan windows or expanded steel?
Build your rig in words!
Me- I'm going with a 2nd gen Trans Am or Camaro. Cut the floor out and firewall out. Tube steel frame rails bent to fit against the unibody front to back. Mount a big block and auto and 205 transfer case, then fit a new floor pan and firewall around it.
Next, a dana 44 front and dana 60 rear with leafs on all 4 corners. Money goes on Adams custom driveshafts.
The trunklid is gone now and I have propane tanks as reserve fuel tanks. Coil over shocks stiffen the suspension and more money goes to 35 inch mud tires and a 4 core radiator.
Next is lexan windows, ballistic foam in the welded on doors.
On board welder, generator, solar, air compressor and fuel pump with siphon hose.
