- Feb 28, 2001
- Dayton Oregon
- 2.3 (4 Cylinder)
- Total Lift
- 6
- Tire Size
- 35"
I've tried to get the engine out of the Explorer this weekend but it's been fighting me, the last of the 4 exhaust bolts did NOT want to come out, first I broke the top off of a no name 6" 3/8 drive extension (it was on the ratchet end after a 18" long extension) which skinned my pinky pretty good, then I tried harder with a name brand extension and broke a 3/8" drive U joint... I was using a 1/2" drive extendable ratchet so pulled out the 2' long 1/2" drive snap on extension (don't remember where I got it but was NOT strap on price...) and asked a little harder with some heat at the manifold side of the bolt with some WD 40... After that decided to go for the bellhousing bolts, the trans dipstick tube is in the way of one so figured I'd get that out of the way... negatory, that 3/8" bolt is STUCK, don't know how, I put it in with 4' of extensions and a U joint with a 3/8" ratchet... I'm not seeing a good other way to get that one bolt out without getting the tube out of the way...
So there's 2 bellhousing bolts and two motor mount nuts holding the engine in at this point... maybe I'll have better luck tomorrow. I'd rather not but I might have to drop the transfer case and drivelines or maybe pull the trans too, was hoping to avoid that...
Today was cut short since I went to the local old iron tractor show thing with swap meet and for whatever reason I had an allergic reaction to stuff I was mowing yesterday, my hands swelled up so took some Benadryl which induced a 2 hour nap...
