Gauge Pod
Broosedamoose
DaMoose is Loose!
South East Massachusettes
MA - USA
Vehicle
Drive
31 x 10.5
Coming in second just makes you the first loser!
Is there a decent gauge pod that will fit the Ranger pillar once the handle is removed? I've tried two different ones and they did not fit right.
Gauge Pod
GlowShift Universal Black Dual Pillar Gauge Pod - Fits Any Make/Model - ABS Plastic - Mounts (2) 2-1/16" (52mm) Gauges to Vehicle's A-Pillar https://www.amazon.com/dp/B001PBJECI?tag=959media-20
Awesome! Thank you! I’m going to be installing the M90 supercharger so obviously I need a boost gauge but what should I put in the second hole?
Could setup an an exhaust gas temp gauge or gauge for a wideband O2 sensor.
Would be pretty useful if you plan on trying to tune the thing yourself or trying to setup a water meth injection
They make a single pod that replaces the upper column shroud. I believe @G8orFord put one in his truck. He said it was for a f150.
  • Gauge Pod
The double looks good! So you ordered one for an F150 and it fits that nice? Does it just clip on or do you have to screw it in place? I think I’m going to go with boost and A/F ratio for gauges. I’d like to paint it to match the interior color to.
Just sits over top of existing. Held in place with plastic rivets, IIRC. I'll try to take a look and confirm.
STEERING COLUMN, SINGLE, 2-1/16", FORD F150 97-01 (AUTOMATIC)​
Should at least fit any Ranger from 2001-2011.
These are some reference photos from my 2009 Ranger Sport.
