- Nov 13, 2018
- Canaan
- State - Country
- NH - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- Total Drop
- 3"
- Tire Size
- 235/55R16
- My credo
- If you don't have time to do it right will you have time to do it over?
You're not assuming I used other than gas line hose are you?Only certain types of rubber will stand up to gasoline. Buna-N is a common one, and Viton is another, even more expensive. What is normally done, is regular rubber is used on the outside of fuel rated hose, and the inner part of the hose is lined with Buna-N or Viton. That is why regular fuel hose is not rated for submersion in the fuel. They do make hose that has the good stuff all the way through and is rated for submersion, but it is very very expensive hose.
