77 LTD II
rusty ol ranger
2.9 Mafia-Don
⭐Supporting Member
Michigan
I dragged the old LTD II out today from its peaceful 15 or 16 year slumber.
Ill be documenting progress in this thread for anyone who might actually care about a smog era somewhat restoration...
Base vehicle...
77 LTD II 351W/FMX/9in rear (2.50 ratio)
Plans....in no order of importance....
1- Go through wiring and make sure its not mouse food
2- Get engine running
3- Touch up rust spots and other paint issues
4- Find decent used bumpers (mostly rear)
5- New headliner
6-New carpet
7- Try to get seat tears fixed
8- Replace the AM radio with a factory AM/FM mono radio
9- New tires/Shine rims
10-Straighten/replace (if i can find any) rocker moldings
11- fuel tank/lines
12- probably brake lines (although at quick glance they seem pretty good yet)
13- Whatever other shit i run across.
14- Seatbelts,
Its going to be a long term project for sure. Goal is not a show car, but a good reliable cruiser.
Any and all comments, input, and criticalness is welcome.
Perfect candidate for a 460 swap...
Nahhh. Im a purist lol. I did contemplate building a 400...as it was an original option and 400s can be mean when done right...but i think ill stick with the windsor. Even if it needs full rebuild
Is it a 351W or M?
If M a 460 will bolt to the trans... just being devils advocate...lol.
Is it a 351W or M?
Windsor. One of the quickest ways to tell is to look at the location of the thermostat. If the outlet comes from the block, it’s a 335 series (351m, 400, etc). If the outlet comes off the intake it’s a Windsor.
77... Does it have catalytic converters? Somewhere around that time they went to unleaded and started installing them.
Awesome Rusty!
I got a 77 Olds Delta 88 in 89, it had a 350 Chevy, paid just over 500 for it, had to sign a note saying I hadn't paid the full asking price to his wife, haha
After cleaning it up and ripping the ragged vinyl roof off of it that got to be a decent auto.
I hope you have a good time with your LTD :)
The word BOAT comes to mind, and not just the way it drives, more of the "bust out another thousand"
Don't forget shocks and steering wheel :)
HEY, where's the computer?
There is certainly enough room for it :)
Forget the laptop there is room for a PC WITH Monitor
I forgot just how BIG the engine bays were on these, "dual batteries, heck I'll put in 4"
The W has the same stupid "sandwich the timing cover between the water pump and engine block" water pump setup as a 302 also.
Is it a 351W or M?
Windsor. If it had a M it would make a 400/460 more appealing. Even though the FMX has a removeable bell.
Valve covers are vastly different to.
it did :)
Awesome Rusty!
Ive always had a soft spot for the late 70s stuff. They make great cheap cruisers and are usually comfortable as hell and pretty easy to wrench on.
I did contemplate an aftermarket EFI for like....5 minutes. But then i came to my senses
Most ltd’s of that era Ive seen had 400’s. Id put a lower geared rear end in it, that alone would increase the fun-factor. 3.73’s would really make it feel like a V8.
I *think* i have a 3.25 3rd member laying around. Or i did. If its still around it could very well find its way into it.
If i end up doing a full rebuild its probably going to get atleast a RV cam in it. It needs a timing chain and im using an early pre emission set, so that should wake it up some too.
The 2.50's were nice though in a way....i could get 20-21hwy with it....and about 11 around town :) lol.
It wouldnt shift into 3rd untill the speedo was buried at WOT
