- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Total Drop
- few inches
- Tire Size
- ~30"
So, you can use the Ranger condenser, liquid line, accumulator, and evaporator core. Only things that change with the swap is the suction hose assembly and the pump. Actually the pumps might be the same, I never checked.
I know. I'm almost certain that the pumps are different, and the suction hose like you said. I could replace everything now and re-use most of it then, but when I find my donor I'd rather just pull the complete AC system intact and swap over, assuming that it works right of course. Avoid evacuating, vacuuming, and filling the system twice. If the system in the donor is no good, then I'll buy everything and rebuild the system with the new engine.
