conversion electric to manual, what's possible, pics
pjtoledo
Toledo Ohio
compared a manual 1997 to an electric 1999(?)
the particular electric case I have has all the bosses needed.
except for machining, the case front halves are identical.
the front output shafts are 100% swappable between U joint style and CV flange.
the shift forks and rails are identical
the parts needed are:
shift plate
shift plate spring
shift plate pivot shaft
sensing switch for shift plate,,,senses low range???
detent
the red circle above the "98+" is where the detent goes. red mark at lower left will be the shift plate sensing switch.
electric shifting cam assembly, the end (hidden) goes in that tiny hole in the center.
the range shift fork roller rides in the channel next to the flat spring. the front coupler (plastic) fork rides on top of the cam.
range roller not quite in it's groove. as the cam rotates left or right it raises the front engagement plastic fork.
better pic of forks and the cam.
ditto
where the plate spring goes, there is a hard to see tab that secures the top end of the spring.
97 M case with 99 E front output driven gear and shaft
manual shift cam plate, note range shift fork roller in slot. plate spring goes to left then up across a retaining slot.
shift plate spring, shift plate pivot shaft (with machined groove) at bottom.
this is the manual case, note no hole for the shift cam rod in the boss.
hard to see, lower center the detent is protruding from the boss, there is a small circle where it is locked in.
the gray rectangle covering the detent circle is a shadow.
99 E front shaft in the 97 M case
on left 97 case with 99 CV shaft/flange, note hole for switch that senses plate position
hole for shift pivot shaft is already located, needs finished accurately
front outputs swapped between cases.
the hole for the switch lines up with the detent, drill the switch first then use a long tool to do the detent.
did I mention that I like to tear into stuff to see how it works???
Why not just push the button and step on the gas!? :D
Been wondering about an electric to manual transfer case swap in my 99 F250 SD....a little knob on the dash doesn't sound very heavy duty to me...and there are 4WD shift codes stored in the computer...not sure why a person couldn't simply swap the cases.
shift plate
shift plate spring
detent
ditto
Awesome set of photos and notes. Thanks, PJ.
A Bowden cable is what was used for speedometers for a whole lot of years, lol
It takes a rotational force(from transmission gear) and transfers it inside a fixed sheath, to another location(speedometer in dash) but as a "flexible cable"
Seems to me if you were to find the right size Bowden cable you could make a short one that mounts in the cab with a knob(like shiftster size) and then you could mount/clamp other end to transfer case shift rod
They make Bowden cables as flexible drive shafts for many applications, so can handle the torque to shift a transfer case
I think someone did that a year or two ago.
I've contemplated grinding a notch in the electric shift plastic gear and setting it up for a push/pull cable with detents on the shifter assembly for neutral and 4hi, just take the motor off and make a bushing for the cable to go into, sounds simple enough but I never got to implementing since I've found manual cases for everything so far...
You can swap to a manual shift transfer case, very easy to do on those.
That little button on the dash powers an electric motor, much like the one that starts your engine.
They swap to manual pretty regular, I think they mostly put a floor shifter in it somehow.
It's hard to really come to grips with it but with that motor and transmission installed the drivers knee is almost right beside the shifter. If the seats and stuff was removed in mine I'd be sitting so far back I'd be near sliding off the back of the transfer case
Kind of what I was hoping for. I haven't looked around yet at manual transfer cases, or looked at the truck itself...but was told there's probably an access plate or at least markings where the transfer case lever and boot would go through the floorboard of the truck.
The shift motor is working now, but with the lack of use the truck is going to get, I figured I might swap to manual t-case at some point...might be an interesting learning project too LOL. I'm not even sure at this point what transfer cases are used in these trucks, that's how far I've gotten into the research aspect LOL.
Yes there is an acess plate you remove and the holes for the boot and linkage to bolt up are all there. Well worth the swap to get rid of that electric shift junk.
Thanks for the information....I figured there may possibly be a plate or other markings in the area where the T-Case lever and boot would go. Now I gotta figure out what transfer case would be the correct one to get.
