1997 3.0 2wd - I recently replaced my O2 sensors because it was throwing codes for them and its due at 100,000 miles. I was also having problems before i replaced them with the engine randomly cutting out for a fraction of a second but will turn back on on its own while I was driving and it got to the point where the engine would fully shut off while i was driving. After i replaced the O2 sensors it was a lot better but the engine still shuts off for a fraction of second while driving. I ended up checking the fuse and power to the fuse, those are both good. But, I checked power to the bank one sensor one O2 sensor and there is no power. I inspected the wiring harness and from what i could see there was nothing wrong. I don't really know what to do at this point.
Here are my codes:
P1443 - Evap emission purge valve malfunction
P1445 - Purge flow sensor circuit high input
P0133 - Oxygen sensor circuit slow response bank 1 sensor 1
P0135 - Oxygen sensor heater bank 1 sensor 1
P0141 - Oxygen sensor heater circuit bank 1 sensor 2
P0155 - Oxygen sensor heater circuit bank 2 sensor 1
P0301 - Cylinder 1 misfire
P0304 - Cylinder 4 misfire
Here are my codes:
