lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
Well, it snowed until about 1 or so around here, then I had to run into town for my parents and after I got back started tinkering with the green Ranger again. Couple odds and ends, then I took a deep breath and cut my factory headlight harness. Snipped the turn signal ends out and installed a Weatherpack connector should I ever have need of going back to factory, then the pigtail for the new turn signals. Got both sides together and tested both sides with the new lights. Have to do a little bit of loom work, then the last of the front clip can go together for good.
Finally turned on the stereo in the Ranger just because I could and man, I miss that… need to get this truck done…
Was about to boldly push forward on getting the front clip together when it suddenly started snowing. Hard. Hurried up and packed it in. Probably got an inch or better laying now. Hopefully that doesn’t continue, I don’t want to have to shovel in the morning.
